I would take a turbo diesel 100 over a V8 everyday of the week. ;<)
*On trails with big boulders...the 80's steering just can't turn into and up on a huge rock especially when the front is locked up. The hydaulics are weak. The 100 just turns and instantly and effortlessly even when locked up. So the 80's struggle and struggle to make it through. The 100 just goes.
OVERALL...on 90% of the trails out there....the 80 can't compete with the 100 on the trails.
John, I believe you're on your third steering rack already? :whoops:
Hardly ever hear of steering breakage in 80s. I did hear of one instance, but that was fixed with an onboard welder and the person completed the trail.
Here's an article I remember reading on the 80 page. It's informative and probably helps out the OP'er
https://forum.ih8mud.com/80-series-...ison-1999-aussie-magazine-dialup-warning.html
Yes...cause the 80's steering is too weak to wear the components. They just won't turn up the rocks and ledges. I'm sure it's NOT good on the 100's system to wheel like that when locked up. Man it sure makes the obstacles easy though. I WILL PAY TO PLAY cause the steering perfomance of the 80 is inadequate. Jeeps turn up the friggin' rocks like the 100 can. Why can't an 80. And hey...you personally keep bringing this up cause it's all ya got.
One last thing on this...you know how many times I've been embarrassed on the trail in my 80's in front of Jeepers and Rovers? You're in a tight place...you can't move cause you can't turn...the tell you to "go" and you can't cause the steering sucks and it won't climb the rock or ledge while turning. You back up, try again...crap! Doesn't happen in the 100.
Another last last thing...you bring up steering...the bits on the 80 are VULNERABLE. The 100's are not. Hell, I was almost stranded after bending rods being hit by rocks under deep water. I couldn't steer until we worked things loose. Barely made it home and with an occassional IT WON'T TURN...JERK JERK JERK the wheel. If I could have the 100's steering on the 80 I'd take it (and replacement racks) in a heartbeat. I was leading the Hummer Club...another embarrassment for the 80-series on the trail...though in most places I blew them away.
This is starting to be a factor if you're not planning on doing a lot of repair and maintenance work. If you are, then it's a non-issue....remebering that the youngest 80 is now 13 plus years old.
pulled fuse and bulb?That's a good question. I'll have to ask my mechanic the next time I see him. He always made it sound like it was a programming thing. I know it was easier to disable the 4-runner's ATRAC, but I really have no idea how he even did that. I just took the rigs in to him in the Fall to put the winters tires on them and disable the ATRAC, then in the Spring to enable the ATRAC and install Summer tires.
TK
There's no steering problem on the 80's. Consider your source carefully.
No play on words here TM.
It is well documented the 80's have great difficulting when turning onto and upon obstacles. In the past even Slee has pointed out that it is due to the lack of hydraulic power. Is it a "problem" or "defect"? No. Is it a under-designed part of the vehicle? Yes...though one of very few.
Nobody can dispute that the steering system on the 100 is far and away more responsive and powerful...and so says Toyota as well. Consider Toyota as your source carefully.
So is there a fix or way to upgrade the short comings of the 80's steering?
