100 transmission fluid exchange & transfer case fill plug q's (1 Viewer)
Bozeman, MT
Has anyone done a full fluid exchange with a pump system on their transmission locally? If so, which shops can do this? Not wanting to drain just 2 - 4 quarts at a time, but rather replace the entire amount (roughly 16 quarts) all at once. Willing to pay a "reasonable" amount...
Forgive me if this thread already exists...Has anyone replaced their transfer case fill plug with a 10mm hex vs. the standard 24mm head? Mine was rounded pretty bad (for the record, this wasn't me rounding it as I only use a 6 point socket). I asked toyota and they said they can only do the factory 24mm plug...not really believing this and thinking a new front differential fill plug (10 mm hex) might be compatible? I don't love hex, but might be better than rounded 24mm. Thoughts and input greatly appreciated.
@Saul Abel we can take care of both of your woes. When doing the trans flush you need to replace the screen element in the pan as well. The parts, ATF and labor will run about $300.
