100 Series Starter: replacement or rebuild
I'm a definite maybe now... starter is about to go out completely. I just picked up a new one from NAPA, and gonna try and work on it a bit when I can this week.
I think accessing the starter is a royal PITA. But, for about $15, I think you can rebuild your starter with parts from Toyota. At least, Toyota has rebuild kits for the 80 series starters, which I think is similar to the 100 starters.
Be glad you don't have the D4D. The starter on that is inside the V and requires removal of virtually everything on the top end.
I think the 2UZ-FE engine has similar painful attributes.....
Yes, you must remove the intake manifold to replace the starter on a 2UZ-FE (the motor in early 100-series in the US)
Correction: the motor in all 100 series rigs 1/1998-8/2007.
Rebuild parts for OEM starter run about $40 from CDan.
They become non-rebuildable with the 5.7L engine (3UR-FE). The whole engine is throw-away.
Welcome to the new Toyota=GM. :rolleyes:
I assumed Toyota changed the engine model designator when they put the VVT-i heads on them in '03. Guess not.
VVT-i = '06-'07 MY 100-Series/LX470
Now I'm feeling really ashamed by my inaccurate 100-series trivia.
I had my starter replace because the nose gear drive bearing failed at 152k contacts were fine. I had a mechanic friend of mine, a jeep guy do it. It took him 2 hours and I asked did the links on replace it help. He replied I did'nt look at them they would of only slowed me down.:)
Labor $100
Starter from Toyota $185
Phil,
That's not a bad track record at 152k miles for your starter Just for the benefits of this group, would you mind giving us the link to the rebuild/extraction process please?
Phil,
I was very happy with the contacts but could not find anyone else that lost the bearing. :confused: Also Im assuming the contacts never were replace prior to my purchase at 75K combined with dealer records.
Alia like I said above I had a mechanic friend do it because I was pressed for time on my beach run down in Mexico. It would of taken me much longer because I would have read MUDs version of the service process.:rolleyes:
Could not bring myself to take my 80 that close to the ocean so I took the 100:hillbilly:
Nothing like cruising down the beach 100 style:steer:
http://www.youtube.com/watch?v=s4A27VP8EwY
Crickey, that's a serious job Ron!!! My back hurts just thinking about it.
^ Its really not that bad; like anything its easier and faster after the initial R&R. But I'd much prefer to do it every ~150k (OEM new) rather than the last 75k interval (Toyota reman).
