[quote author=slambson link=board=2;threadid=16481;start=msg159647#msg159647 date=1084939724]
I appologize for my ineptitude. I believe I found my fault. The search defaults to 50 results and 60 days at each visit to the search.
I found this nice thread also:
https://forum.ih8mud.com/index.php?board=2;action=display;threadid=14192;start=msg132433#msg132433
I am a moderator on a few of the Mitsubishi Starion/Conquest boards and yes it does get a bit old seeing the same posts over and over.
www.starquestclub.com I guess you either accept it or drive yourself crazy. :
Personally I just drop out of the scene for awhile and then it's all new when you come back.
Brakes on the 'new' 92 stink. I can't even get them to lock up. Put new rear pads on and bled both sides on the brake-level adjuster majigy. Nada, so I bled both fronts and pulled pads and measured caliper thickness'. Pads are near new and the drivers side is .002 less than the brand new thickness. The other side has some surface gouges on the outside of the rotor but still has plenty of thickness to be turned to. The pads appear to have molded to the gouge. Master cylinder appears to be new.
I used Valvoline synthetic brake fluid and flushed a full quart through the system. Oh, had to replace one rear brake cylinder. One other bit, if you happen to loose your can for your Mityvac a couple of barb fittings in an old brake fluid bottle works although you can't pull quite as much vacuum.
Anyhow, I'll keep plugging away at it looking for issues. I guess I'll be checking out the front calipers further. I did take the suggestion and e-mailed a few individuals looking for pics.
[/quote]
No ones going to like to hear this, but you shouldn't use synthetic brake fluid (DOT 5) for better feel or even on the street.
Heres the deal, DOT 4 (the cheap stuff) is really best for stopping distances and feel, but it gets comtaminated (sp) with water if the system isn't maintained. DOT 5 has a better flash point and doesn't contaminate (sp again) with water.
So why do all of the racers use DOT 5, well they have soooo much braking ability that they welcome a little feel to the breaking system and the fluid doesn't boil off as fast.
If you can already mash your foot to the floor in your LC, well more feel/mushiness is the last thing you want as is DOT 5.
Just for a point of reference, I also drive a 1999 Ford Lightning 4600lbs and have 4 wheel disk brakes and 295/45/18 size tires, so our trucks are some what simular in weight and breaking (4 disks). I bet you I have 2x the breaks (modded) that my 93 LC has and the Lightning still doesn't stop very good. There are a few Lightning guys running around with get this, F50 Ferrari front break kits (2 disks and cals) $4000 and it stops just OK.
Point being I get wood went I rent a Ford focus and hit the binders, so don't expect much EVER from a LC without hitting a brick wall.
