Thanks for ordering!
Below is a video of how I do it with the included wago quick-disconnect that came with your shifter trim plate. :
I just snip the two wires, strip them a bit, and lock them into the quick disconnect when I go to reinstall the OD switch, this is much easier than the alternative method which is showcased in
This is much easier than the "proper" way to do it which involves popping two pins out of the OEM connector which is underneath the right side of the shifter. This method is showcased very well in chowcares video here:
tl;dr: Snip the shifters from the OD switch, pull it out and install the trim plate, then use the wago quick-disconnect terminal block that came with your order to splice the wires together. If you have any more issues shoot me a pm or give me a call!
Bahaha way to go with me following directions.
I've been knee deep in other maintenance and forgot about the quick connect you supplied. I just cut the wire, installed the plate, and soldered it back together.
Thanks for the video! That would def be a good one to add to the product page.
100 Series Shifter Trim Plate
Fits 100 Series Toyota Land Cruisers and Lexus LX470 (1998 - 2002) If your shifter plate is anything like mine, it's scratched, the plastic is bubbling on the inside so that the indicator doesn't work as it should, and the shift lock cap is missing. Lucky for us 100 series owners, toyota has...
cruiserdm.com
Thanks again for the part!
