100 Series ABS issues
Charleston, SC
Hey! So I have a 100 series here with some braking issues. I start it up and I get these lights: Brake, VSC off, VSC Trac, traction, diff lock. I also get a very high pitch constant beep and occasionally strange sounds from brake booster/accumalator area. I was in reverse a few days ago and the car almost locked up I could barely go backwards. Thought it could be transmission related but thinking it is all brake system related since I ran the codes and came up with 7 ABS codes. I included the codes below. Any help is greatly appreciated. Thank you!
C1223- Antilock brake system control system malfunction
C1241- Power Source Voltage down
C1249- Stop lamp switch circuit
C1252- Hydraulic brake booster pump motor on abnormally long
C1256 - Accumulator low pressure malfunction
C1268- Transfer L4 position switch malfunction
C1340 - center diff lock
Did all of the lights and codes start at the same time? My first guess would be a voltage issue. A number of these systems are very sensitive to correct voltage. Test voltage at the battery and at main connection terminals for brake booster, etc....
