While driving under normal conditions, my 100 slows and jerks hard to the right?
I did get a beep. We have ordered ABS sensors which my mechanic thinks is the problemDo you get any beeps or flashing lights on the dash? Could be a loose wheel bearing causing an ABS speed reading issue throwing the VSC on.
Yes. I had someone tell me that if the steering rack has any play in it, it could cause the ABS sensor to react. I have a new rack ordered because we do have some play that causes a bit of a floating feelingdo you have VGRS?
Diagnosing Violent-Jerking Steering Issue (VGRS)
I will preface this by stating that this is not an issue of loose wheel bearings trigging ABS system to grab a tire. This one has @2001LC and I somewhat stumped. I've also gone through most of the VGRS related threads and found good info to inform investigation but no conclusion yet. Paul has...forum.ih8mud.com
