Nav delete, so I could run a modern Pioner head unit to get wireless car play, android auto.
Door drivers are scan speak 6.5s, these drivers are spendy af but they have surpassed my expectations and there is no where to upgrade from here in this size. I made some custom mounting baffles/spacers in the doors out of acrylic. Ran new power wires back to the replacement amp. Most of the work and effort should go into property treating the doors with mass load vinyl, a foam isolation layer, and sound deadening material.
Running 2 way with the 2" BLAM widebands, mounted in pods up near the sail panels. Pods were made out of pvc caps and some swivel mounts I found on
Amazon. I ordered some permanent ones that are made out of aluminum to go on the sail panel itself, just waiting on the install when I do some other work. No way to hide them, but I don't care how they look, the sound is incredible. I have them crossed pretty low to avoid separation issues and beaming from the woofers, Around 400hz from what I remember, they handle it fine. My ears are sensitive to hiss/sizzle/the very top end of the range so I don't miss dome tweeters at all.
I kept the stock rear door speakers that I can selectively play or not with my twk-88.
For sub, I got tired of messing around with the stock location after a couple of trials and errors and built a real box for a JBL GTI-12" that I can take out for trips, but otherwise lives in cargo area strapped to my fridge slide. It's a fantastic driver, one of the best SQ woofers ever made and can get louder than I have any business listening to at my age.
All time alignment, crossovers, EQing, etc is done through the Twk-88, worth every penny, not even worth doing a sound system without a capable DSP in my opinion.
And this is all powered with a 5 channel amp for front stage and sub and a small 2 channel for the rear door speakers. The amps and twk-88 are all under the passenger seat. You can create different "profiles" in the twk and with the click of a knob, I go from front stage and sub only, to front and rear both playing and fading ability for the rear passenger/passengers when needed.
This was the best I could do without getting radical and cutting holes in the dash. It's the best sounding system I've ever had, mostly down to, good door treatments, quality drivers, and the DSP tuning.
