1 wire or 3 wire alternator sbc (1 Viewer)
Northern Va
just checking before i make a purchase for 100amp alternator the 3 wire is if you have a external voltage regulator and the 1 wire is when there is a internal regulator? let me know if i am way off base. im thinking a 100 amp should suffice for just a couple of hella's and 25 watt receiver deck. any input is appreciated if you have other recommendations.
thanx:grinpimp:
rule of thumb is to add up the total current everything pulls and then doubble it, as you dont want to run the alternator at max
GM alternators will have a built in regulator.
I think running 3 wires is better, as it gives you a battery idiot light (which can be useful) and it energizes the alternator so it is charging right away at low rpm's.
