09’ LC w/ 177k What should I look for?
Northern Virginia
Going to look at an 09’ LC tomorrow up in VA. 2 previous owners, spent its whole life in MD and has a solid maintenance history. LC has 177k on the clock and they want $29k for it. I have an 03’ LX 470, but I am a bit novice when when it comes to the 200’s. What items or checklist should I go over when inspecting? What replacements/repairs should I expect creeping up around 200k on the odometer? Thanks for the help.
Two things that jump out to me are frame rust and the state of the cooling system. To me, significant rust on the frame would be a deal-breaker.
At that mileage, I would expect to see new cooling system components. A new radiator / hoses / water pump / etc., are all things to expect to be replacing (if it hasn't already happened). My 2013 developed a leak in the "valley" under the intake manifold at about 95K miles. It started to leak coolant without actually dripping anything on the ground.
I would say that if this truck has not had cooling components replaced, you should expect to be replacing them. Not a big deal, but something to consider.
Lastly, I would say that you should ask to see records that document replacement of drivetrain fluids. At that mileage, I would expect the transmission / differential fluids to have been changed at least once.
Not a bad price. Like he said above. Open a account at toyota.com or toyotaowners.com and put the vin# in the maintenance section. It'll give all work that was carried out by dealer. Other than that base line like any other vehicle with that mileage. Good luck
