07 Tundra Brakes on an 80?
Discussion in '80-Series Tech' started by Buckums, Feb 28, 2007.
  1. Buckums
    Buckums
    108
    Aug 24, 2005
    Bfe, Arkansas
    we've all seen the commercials, and those big 07 Tundra brakes look hause. They come to mind everytime i am pulling a trailer. would it be possible to fit these bad boys on an 80 with wheels, etc. ?? i may be dreaming but it i just had to ask.
    :cheers:
  2. kbellve
    kbellve
    152
    May 30, 2005
    Hubbardston, MA
  3. Buckums
    Buckums
    108
    Aug 24, 2005
    Bfe, Arkansas
    i know, but is there any creative way to change the 80 to five lug?
  4. Josh83
    Josh83
    757
    1
    Nov 26, 2003
    Frankfort, KY
    Anything is possible, if you want it bad enough. It seems like it would take a lot of fab work for probably minimal benefit.
  5. Arya Ebrahimi
    Arya Ebrahimi
    3,378
    92
    Dec 2, 2003
    Rockville, MD
    Perhaps swapping the hubs off of a FZJ105? I've come to understand that they are 5-lug like the 100's and now the Tundra. It also seems that the solid axle is derived from the 80-series axle, so perhaps the knuckle balls are the same? and thereby the knuckles?
    Purely speculation, but might be worth looking into further if you really want to do this.
    Ary
  6. MTNRAT
    MTNRAT
    1,181
    17
    Mar 27, 2003
    Fernie B.C.
    If your pulling something heavy enough that you want those, you would have trailer brakes.... wouldn't you? :)
  7. Arya Ebrahimi
    Arya Ebrahimi
    3,378
    92
    Dec 2, 2003
    Rockville, MD
    Not that I don't agree with you, but the 80's brakes have often left a bit to be desired in my opinion.
    Just imagine an 80 series with a 4.7 or 5.7 Toyota V8 and Tundra brakes, now THAT would be kickass and would solve all of the 80's "shortcomings" in my view. :D
    It's hard to beat the 80 for all around ruggedness of design and functionality, but the go and stop part of its job have always been a bit meager(at least in stock form, the SC presumably fixes half the 'problem').
    Again, all just opinion, as I'm sure you'll find a lot of around here :grinpimp:
  8. F0RSAKEN
    F0RSAKEN
    236
    Jun 4, 2006
    All you guys who complain about the lack of power in an 80 series need to drive a 2nd gen 4Runner for a while. After a few months of that, your 80 will feel like a powerhouse.
    As for brakes, I dont know the difference in diameter between the new Tundra's and the 80's, but Id try more aggressive pads before I did something extreme like convert over to 5 lug hubs and bought new factory parts off of a new vehicle (EXPENSIVE). Or maybe look to see if anyone offers 6 lug rotors in a larger diameter with custom brackets/after market calipers.
  9. chibo
    chibo
    942
    1
    May 27, 2006
    Tempe, Arizona
    Wonder when people will start wrecking these so they can be picked apart vulture style ;)
  10. Buckums
    Buckums
    108
    Aug 24, 2005
    Bfe, Arkansas
    i used to have a 2nd gen 4 runner with the 3.0. it had 170K on it and it could barely get out of its own way. the trailer that i pull is not heavy enough to justify trailer brakes. its only a 15 ft boat and motor. but i agree that the 80s brakes leave a lot to be desired once you put bigger tires and a trailer of just about any size in toe. is there anything you can do to help out the braking on an 80 besides 100 pads? doesn't seem like that would give you much.
  11. Doc
    Doc
    5,920
    Media:
    33
    Albums:
    1
    369
    Apr 26, 2004
    Utah
    If you're looking into this, I'd also suggest contacting Wilwood and seeing what they have that can help out.
  12. FirstToy
    FirstToy
    4,432
    71
    Nov 27, 2003
    Socal
    wilwood, brembo, or other quality aftermarket would be cheaper to go big and directly 6lug compatible.
    it's not just the rotor size (which will be limited unless you want to go 17-18" wheels) but also the fact the new Toyotas use EBFD and electric assisted booster.
    Also, what about just replacing old parts with factory fresh from Cdan? Maybe that will help also...
    look at the figures, you may improve feel and fade but maybe not braking distance. The 80 stops as short as a 100 series or GX470
  13. blarsen
    blarsen
    280
    22
    Oct 18, 2006
    Pleasant Grove, Utah
    I put Brembo rotors and EBC green stuff pads on all 4 corners.. MUCH better than stock braking and not a ton of money.. I found my parts on the net/ebay and I am into them about $250 for everything..
    later Bret
  14. Darwood
    Darwood
    1,957
    7
    Oct 8, 2003
    Z.O.W.I.E. Headquarters
    You wouldn't need to convert to 5 lugs if only replacing the front calipers. The front disks bolt to the hubs. The hubs have the lugs.
    And as FirstToy pointed out a lot of it has to do with the electric assist booster.
  15. IdahoDoug
    IdahoDoug
    8,848
    248
    Aug 9, 2003
    Don't go experimenting with brake systems on a daily driver. If your 80 will not lock the brakes at fwy speeds with the ABS fuse pulled, then you have a problem with your stock system. Best money spent would likely be for new rotors and pads all around. The 100 pads don't improve the braking, they just last longer than the stock size pads. Unless you count the placebo effect. ;)
    DougM
