The front end of our truck has been in need of some TLC for a while now.
It started last fall with a nice clunking when the truck hit good size bumps.
Turns out the driver's side wheel bearing was done.
So back a few months ago I did the wheel bearings and seals, both drivers and passenger side.
Clunking got better but was still faintly there.
Well a month later it started getting worse so I took another look and it turns out the driver's side lower ball joint was also gone, so yesterday I finally got around to changing it.
I did a fair amount of online investigating before ordering anything as I didn't feel like parting with all the cash required to purchase the OEM ball joint / LCA assembly.
After a couple of days of research I decided to run down to the local NAPA and order two MOOG K500017 ball joints.
The driver's side seems to be the only one gone but I like to replace front end components in pairs so I got two, esspecially with a high mileage truck.
I tooks pics (sorry if some are blury) of the entire process as I found online information to be sort of scattered in bits and pieces. Perhaps I just didn't find what I was looking for, so hopefully this thread isn't a waste of everyone's time!.
The following is the step by step prcoess of how to R&R a lower ball joint on an '07 FJ Cruiser....
Hope it helps!
Hope it helps!
