Hi to everyone:
I'm hoping to locate someone who has knowledge or experience installing an OME suspension lift and at least 33" tires on a late model Cruiser. Being unable to get one without the hydraulic self leveling suspension, I will need to remove and or disconnect this system in order to install the OME lift. I have heard this is possible and has been done, but it was on a 2000 model. Concerns relating to new 100 series models and not knowing for sure if Toyota has made any changes to the overall system, thus complicating or even making this modification impossible is the worry. Also a concern about larger then 265 or 285 series tires is a question, weather or not the ABS or other computer controlled system will complicate this change. So, if anyone has a handle on these concerns I'd REALLY appreciate hearing from you! Thanks very much, Mike
