02 Duramazx 6speed into 40
Kamloops, BC Canada
Website
www.shopraddcruisers.ca
I was contacted by Daniel from Alaska asking questions about installing this particular setup.
He has fit the engine tranny combo and has his custom AA bracket to mount the Atlas 2.
What he was wondering is how hard it would be from this point to install the electrical?
My lack of knowledge with this particular engine leaves me asking the same question, I suggested he pull the wiring harness and pull it appart getting rid of the items he will not need.
Any more insight would be appreciated and if your reading Daniel, sign up and chime in....
Rob
I haven't done one or even poured over the schmatics...but you will have to deal with the fact the ECM will be looking for other modules to be on the communication bus. It will set quite a few U codes without seeing the HVAC module, IP, EBCM, ect...
You will also have to handle the electronic acutation of the accelerator, but getting the pedal and associated wiring (and module if it has one) should handle that.
Then there is the Theft Deterant built on those vehicles.
Probably going to have to have someone crack the Calibration files on the ECM and eliminate some stuff.
I know this probably isn't much help, but what I know off the top of my noggin.
