I have a 94 so things are a bit different as discussed here before. I had to bend the relocation brackets for the washer bottle a bit and dissregard the directions on which side to mount the bracket on for the left side of the washer bottle but it worked fine and the right side bracket needed a tweak to let the cruise controle cable to rout with no chaifing against the support. I had to relocate some wire harness under the second battery tray to under the air filter housing but it was as easy as a disconnect and reconnect. There is an AC hose that runs directly under the tray but I dont see that as a problem, yet. The washer bottle came really close to the AC hoses going into the firewall but after a tweek and bend cleared by 1/2" The air chamber found on 93 and 94 was as easy as a cut off tool and some primer, (need to paint it later as I ran out of black painting the frame and axles.) and as you can see the hose within a hose solved the problem of finding a new hose for the application. I used the smaller hose and cut 2" off and stuffed it in the larger hose and gave it some lube and slid it on the air cleaner assy. Very tight fit. Trimed a bit off the tray and it fit right in, dropped the second battery in and I am ready to wire up. I am placing the Sure Power isolator on the back side of the batt tray. Now the $250,000 question... Would someone please tell me how to wire the alt to the isolator. Detailed instructions for an idiot please. I understand how to do the battery cables but the alt wiring has me stumped. what wires and colors are the things I am looking for. The directions say to remove all the battery wires and connect them to the seperator but the wires are held in with a harness plug. What to do with that? Cut and splice or something simpler. I'm a wiring dolt so go easy on me. I have read the archives and I don't really see anything that relates to the alt wires
Thanks for the input in advance.
Thanks for all the help.
