FAQ: Member Suspension Lifts
Socal
Keep the commentary limited
1. What lift Kit / components did you use? Include Spacers, if any.
2. Why did you select that particular lift?
3. What tire size are you running?
4. Rim specs - 16x8 w/ "x" backspacing
5. Alignment issues & resolution
6. Have you had any rubbing issues?
7. Did you have any Driveline issues? What was the cause and how did you fix it?
8. What is your main on and off-road uses of vehicle?
9. Are you happy with the performance on and off-road your for your use.
10. What would you do if you were going to do it differently?
11. Any plans on modifying the lift or other related components (Tire size)?
Include any links describing your lift or issues.
Include a photo showing the lift and an action shot
