Alternative 6x16" wheels to 70-series stock steel wheel 6x16"?
SC
Website
www.twistedintentions.com
Hi there,
what 16"-wheels are you running as alternatives to the stock 70-series stock steel wheel 6x16"?
The stock wheels seem to be difficult to get and I need some info on which wheels from other vehicles fit too.
The wheels I would like to have should be between 5,5 and 7" wide and 16" in diameter. 3-3,75" BS would be perfect as I want t9o fit the wheels on Hilux / Mini-truck axles.
BTW: If you happen to have stock wheels and want to get rid of them please post in my "wnated"-thread: https://forum.ih8mud.com/showthread.php?t=94002
I appreciate all your hints and suggestions.
Thanks in advance + best regards,
nose
nose said:
Hi there,
nose
As of last year Unique 7760 series. Stock they are 4" BS (it will fit fine) however you can have then custom BS'd at the factory to 3.5" for a nominal fee.
21-7760 is white
42-7760 is black
16-7760 is chrome
Don't know if anything has changed with these in the last year that would make things different.
hth's
gb
21-7760 is white
42-7760 is black
16-7760 is chrome
hth's
gb
Hello Greg,
thank you very much for the info. I will check with them if they also have a 6" wide wheel. I plan to run 235/85 R16 tires (real 32" dia, ca. 9" wide). I want to stay as narrow as possible....
If I cannot fnd stock wheels (which are great for certification purposes) I will have to buy these....
Thanks again + best regards,
Norbert
Greg
What wheel (diameter, width and BS) and tire size/brand are you running on your BJ74?
nose said:
Hello Greg,
Norbert
Not sure about the 6x16" wheel with the correct inner from Unique. I don't see one on the sheets I have.
Order the factory 16x6 with 3.75" BS might be your best solution. They are very heavy duty, and the part number is listed on this site a few times.
hth's
gb
Glenn-BJ74 said:
Greg
Unique 16x7 with 4" BS on 1.5" bolt on spacers.
255/85R16 for daily driving
35x10.5x16 SSR's for fun
hth's
gb
With the 1.5" spacers on the Unique 4" BS wheel you have an effective 2.5" BS - right?.
