Coolant hoses microfiche with part numbers..?
San Francisco Bay Area
Anyone have the microfiche or picture showing all the coolant hoses with the Toyota part numbers.
I got a box of replacement hoses marked with the toyota parts numbers and want to make sure I put the right ones everywhere.
Thanks.
I recently replaced my cooling system hoses. It was actaully pretty easy to just match them up. I'd remove an old one and compare it to the new ones until I found the match.
Hoses are a pain. They are part of three differnt systems: engine cooling, oil cooling and cabin heating. Below is a list that I developed the last time I purchased a set of hoses. Some of the parts were superceeded, according to my dealer, and the old number is shown in the column labled "previous". I've referenced the microfiche page number and item number in the "reference" column. I've included those pages below in the following order: 1F4, 1L4, 4K5, 4L5. The last two will be in the next post. I hope this works & helps.
edit...This is "mostly" correct. I had to go back a couple of times to get all the right hoses (the one's in yellow were some that were wrong the first time). I'm not sure if I updated the table after I got all the right parts...
Sweet... Thanks for the pictures.
I was trying to match them up but considering it has been since last year when I took some hoses off I wanted to confirm with some pictures.
Would you happen to have them for the '62? I need to replace the hoses coming off my water pump.
