Riad said:Is it just me or the search function doesn't work . I just dis a search on "15" wheel" selecting "80 Series Tech" and nothing, I must be doing some thing wrong. I need more coffee
Your FJ80 came stock with 15" wheels, the FZJ80 (LX450) came with rear disc brakes and 16" wheels. So far everybody that I have seen on here that have put 15" wheels on a FZJ80 have had to modify something, ie. grind the calipers down. Personally, I would not want to do that to my vehicle.Jason Andrews said:My type of 15's will. The eagle alloys. I think the 1069? My roommate has a '03 Tacoma and he went from 15x10's to 15x8's and they were the only one that fit.
You have to go with less backspacing or use spacers if I remember it correctly.Kasprzak said:I understand the bolt pattern to be 6 on 5.5 with 4.5 backspacing. Just trying to find out if a 15" wheel with the same pattern will fit, or will rotors/calipers prevent fitment. Thanks
CodyRx7 said:You just have to bolt them on tight.......and drive until they stop making noise. Driving through deep puddles will put the fires out.
