Headers for a Small Block Conversion
I just purchased a '68 FJ40 with a 383 already in mated to a new venture. I plan on adding power steering in the future and was wondering which headers I should install that will accomodate a Saginaw conversion. Any help would be great! Thanks.
THESE have always seemed to get very positive reviews... I have seen them, and they sure look nice and seem to work well.
Butch's thread detailed some very nice work also.
Good luck!
-Steve
apparently the ram horns have the best flow for a stock manifold, and they are basically block huggers that stay out of the way of everything... drop right down in between the frame rails doesn't get much better than that
Here's a block hugger pic with saginaw.
The issue here is I was able to mock mine up before welding anything into place and knew it would fit. Since you didn't install your motor you might not have blockhuggers as an option based on engine position. You will hear many others mention having to deal with header leaks ... They do require some extra care but will not leak if you use thick flanges and retorque header studs/bolts every so often.
I really like the Sanderson manifolds Steve posted up and would have likely used them had I known about them at the time of my build.
the problem with that last pic, as i have mine installed the same way, is that if you ever have to replace the header gasket you have to remove the steering arm to pull the header off.
Hmmmm. Installed these headers with the steering in place.
The advantage of the Sandersons is that they're supposed to flow a bit better than factory ram horns, they sit closer to the head and you don;t have to worry about scrounging junkyards and hidden cracks in old iron. They are supposed to be less likely to crack than brand new rams horns too.
One of our guys here has been running them on a SBC in a '40 for about 5 years now. Lots of dunkings in 35-40 degree glacial rivers whileat full operating temps. No cracks yet. ;)
I like the standard block hugger myself. But I'm a cheap bastard. ;)
And I avoid the GM saginaw steering anyway for the Scout which keeps the intermediate shaft over the frame instead of inboard of it.
Mark...
