I checked the stealer and they quoted 53 for it. I know I can get it cheaper from Dan but still will be more than I want to spend. Any comparable manufactuers? I dont want to do it again in a year but dont want to pay those prices either.
FAWWK. wish i knew this a month ago when i did my gasketFJ40Jim said:The best gasket is a Felpro MS22813. Get it at Advance autoparts.
The OEM gasket is foil crap that burns & fails. the Felpro is a nifty material called graphlex, IIRC. It's slickery and almost burnproof. Plus the gasket has large fire-rings.
If you want the crap OEM gasket, just buy anything other than the felpro and you'll get the punched foil gasket.
yournamehere said:How many bananas is a manifold gasket replacement. And how long should it take me?
$200 for new/used manifolds or planing? I'm really hoping that my exhaust manifold is not cracked and at worsed warped. I read a thread here with someone claiming it costs ~ $40 to get plane?? What cleaners did you use? When doing it over a spread out time did you shelter the exposed block area? If so how... want to know because this will be my aproach to doing the job.GLTHFJ60 said:As in how hard or how expensive?
For a 60, I'd say that it's a 6 or 7 out of 10 just due to all of the vacuum lines and crap. It took me about 10-15 hours to do, but that was spread out over a long time and I also documented everything extremely well. I didn't want to screw it up.
For $$$, I spent about $200 between the manifolds, the gaskets and cleaners.
How many bannanas on the head gasket replacement (level of difficulty)? Cost on Machining, time and extra $ for misc things ect?jwest said:Depending on your future plans, you might want to consider the head gasket set (HS9833PT1), and just use what you need. Shop around for good pricing.
It could save you both time and a few bucks in the long run.
GLTHFJ60 said:I thought that it was at least half-way decent.
Here you go.
https://forum.ih8mud.com/showthread.php?t=57153
