I have a 99 LC and I am thinking that until I have the money I might level things out a bit and crank the t-bars is there a how to somewhere?
subspd said:I have a 99 LC and I am thinking that until I have the money I might level things out a bit and crank the t-bars is there a how to somewhere?
Greg B said:Jack up the front end until the tires are off the ground. Start cranking the adjustment bolt. It's at the back end of the t-bar. I think it takes a 30 mm socket to turn it. It's tight, I use a 2 foot cheater bar to adjust mine.
Make sure you measure from the top of the wheel to the fender lip before you do anything while on level ground. This will give you a base height to work from. Then crank a little bit, re-measure, crank a little bit, re-measure, etc. Once you have one side at the height you want, crank the other side to match.
You probably already know this but, this will only raise the front end. You will still need to change out rear springs or use spacers. If you use spacers, you're going to have a wild ride. The stock springs are soft as it is, causing body roll. Raising the center of gravity is only going to make them even worse.
brett0004 said:I Just put an ARB bar on mine and want to lift the front slightly, If I crank up the torsion bars will I have to get a wheel alignment done, and can you go too far with the adjusters or can I just take them to the limit and level it out side to side.
macneill said:Hey Greg, if you're free next weekend ya wanna come up and do mine?! I'll buy the pizza and beer.
spressomon said:Good info John,
Also be sure to PB Blast the T-Bar adjuster bolt threads several days (repeated apps for mine) before putting a wrench to them...
I'm curious to learn more about this 'Land Cruiser Lean'. My '00 LX seems to be leaning on the DS as well. The difference is about 0.5".dclee said:In my case, the driver side was slightly lower than the passenger from the dealer floor. The ubiquitous "Land Cruiser Lean." With the ARB bumper the front dropped about 0.75 inches. I ended up cranking the bolt 4.5 turns on the PS and 5.5 on the DS to get it back to stock height. Still just a slight lean, but not nearly as noticeable. YMMV.
white_lx said:I'm curious to learn more about this 'Land Cruiser Lean'. My '00 LX seems to be leaning on the DS as well. The difference is about 0.5".
I was expecting that the AHC would take care of this difference. What is the procedure to get it right? Adjust the AHC sensor, or crank the T-bar?
'00 LX470 - BFG AT 285
Try adjusting one of the front AHC sensors to even things out. Or heck, adjust all 3 of the sensors and give it 2" of lift.white_lx said:I'm curious to learn more about this 'Land Cruiser Lean'. My '00 LX seems to be leaning on the DS as well. The difference is about 0.5".
Greg B said:See what happens when I start agreeing with Derek on stuff!
