semlin
curmudgeon
So I got the following comment from a board member about the oem 80 recovery loops in relation to some trip planning. I have never needed more than a light tug to get my truck loose but I had always understood the stock 80 loops were plenty adequate recovery points if the going got rougher. Would folks who have had to use them in more serious recovery mode agree or disagree with the following comment (and please do not flame Mark if you disagree - He did not post it here and I am just trying to find out information not start something) ?
Mark W said:I was under an FZJ80 today and took the time to look at the loops under the front of the frame. I haven't had much reason to look at these with a critical eye before 'cause we don't get '80s on the trails too often around here.
These loops are not suitable for a strap recovery. They may hold up to a winch recovery (to be honest they look to be intended more as tie down points). A good vigorous yank on a strap can easily and often approach the 20-30 thousand pound strength of the strap. It's not unusual to need that kind of yank. I would not be comfortable counting on that loop to take that stress. More importantly, there is no way to connect a strap to it without using a shackle. If the loop does give way you now have a heavy projectile being propelled at the end of that rebounding strap. Potentially deadly.
The good news is; The spacing of the holes seems to match a standard tow hook. It will still be in a far from ideal location, but if you are willing to dig into the mud or dive under the water if need be to hook it up, it will be suitable for use with a strap with hooks replacing the loops.
If you have the usual factory (or aftermarket) receiver tow point on the back of the rig, we will have a couple stab in shackle units that will convert this to an ideal strap recover point.
Mark...
