Dash lights and heater stay on after key removed
TOY350
#1 Super Guy
Grants Pass, OR
I did a search and only came up with starter related problems. My starter was replaced 10K ago.
We got some snow tonight so the family piled in and we went for a cruise which was fun. When we got back we unloaed and I shut off the 80 and removed the snow torn tarp that fell on my 60. After a bit I was going to call it a night and noticed I hadn't rolled up my windows all the way on the 80 (ventvisors for air). So I got in and rolled up the driver and I couldn't roll up the passenger (window lock on because son was playing with his rear window and it wasn't going up very well). So I went back to the driver side took the window lock off and rolled it up and shut the key off and took it out. The heater blower was still going and my parking brake, ABS & CDL lights were on (CDL switch is engaged). I tried turning it back on and off and nothing happened. I shut the door and hit the remote and nothing happened, no lights blinking or anything. I then disconnected the negative side of the battery for 10 seconds and now everything is off and the remote locks the doors. I haven't tried starting it and seeing what happens when I turn it off again, but I will tomorrow.
:confused:
When I bought my wife's 80, everything came on when I opened the rear hatch. The hatch ground wire was bad, so power went through the door light switch and into the ground wire, then backward through some other hatch component, up to the ignition switch. Power to the switched, aux side of the ignition was the same as having the ignition switch on. Everything came on dim, including the ceiling light. You could have something like that, if it's a door it would also explain non-working locks.
I have had the rear hatch light be dim at times as well as set off the "key in iginition" buzzer noise. Sounds like I should start there.
Thanks
TOY350
How did you fix it? I think the rear hatch harness runs from the roof to the rear hatch at the upper lefthand side. Did you disassemble the rear hatch to get at the ground or?
Thanks,
Garett
I pulled some interior hatch trim off, and pushed a new wire through the tube. I think it pretty much followed the old wires down to the jack stowage area, where I connected it to the original ground wire. It was broken somewhere in the hinge area, I just needed to bypass that area with a new wire. Good luck, hope it's that easy to fix!
Follow up: The problem was a bad ground connection at the plug. The plug is under the headliner and connects to the wires that run through the rubber tube in the hatch. Basicaly the same thing Scottm talked about, but I was able to trace it right to the plug. I cut the grounds and bypassed the plug using a new connector that I can disconnect if necessary. It was the plug that feeds the rear dome light.
Thanks for following up; I wish everyone would as this helps in solving the problem for the next guy.
Kudos to Scott for pinpointing the problem!!
-B-
I had the same problem several years ago, open the rear hatch and the dash lights would come on. Also the rear wiper and defroster would not work. It was the plug behind the headliner right where the wires come in from the hatch. I just soldered the wires straight through without the plug. 2 years later, no problems.
Thanks
TOY350
This exact thing is happening to me. Thanks for this thread as I will check the hatch grounds today. :cheers:
Okay here was my fix. I started by getting under the headliner, and pulling on wires. That produced flickering of the light, and the key buzzer to come on but the problem was in a connector in the hatch. The headliner is a small pita so start with the hatch first. Pulling on wires identified the culprit as a 2 wire connector next to the wiper relay. Black/white striped with silver dot wire and red/white striped w/ silver dot. These wires have a connector and mine had gone bad. It turned out to be the black/white silver dot wire so I bypassed the connector for that wire and all seems ok now.
While I had the hatch trim off I disconnected the courtesy light switch for the hatch. I was tired of camping and worrying about the "door open" icon on the dash being lit for days. Two wires run to the lock mechanism of the hatch, with a convenient connector right there so I disconnected it. No more dash icon with hatch open. Of course the courtesy light won't work in "auto", you have to manually turn it on.
Glad you figured it out JonB. I also camp and never thought about the dash light regarding the doors open. I changed my interior lights to LEDs which can run a long time, but I don't know about the dash "door open" light. I usually will just take a screwdriver and "lock" the hatch and tailgate latches to fool the system into thinking everything is closed, but you have to be careful to remember to unlock them before you try and shut them.
Wow, and I was just going through these same dash-remains-lit, rear-wiper-not-working issues and thought it was an isolated weird incident. Just goes to show the enormous collective wisdom of this board.
Thanks for the posts guys--off to trace wires now!
Yep, the rear wiper had quit as well, and now works again.
Crossing fingers for this weekend to pursue and solve non-working rear wiper and ignition buzzer/dimming of interior lights with hatch operation. A pre-emptive thanks....:beer:
