TiredIron's Homemade sliders
Kingsport, TN
Website
tired-iron.mounet.com
Here's some pictures of my sliders, a friend of mine and I designed these and made them from scrap metal from a local salvage yard. The round tubing is 1" and is 3/16 thick as is the 1.5 square tubing They bolt in the rear and will be welded in the other connecting points.
Glad to see your imagination didn't stop with the axles!
I also made the wifes sliders....cash savings was so worth it.
Have fun in Moab....we did last year.
Those look nice!
So what's your next mod?
TiredIronGRB,
please write up the procedure/steps you went through to construct these and any other detail info. I will link it and add to the FAQ slider section currently under construction. If you don't mind.
The round 1" tubing is schedlue 80, it comes out 6" and is angled up 25 degrees up from the square 3/16" x 1.5" tube , we used 3/16" x 2" flat stock to make the rear mounts that bolt in the running board mounting holes, the DS also mounts on the front with the 3/16" x 2" flat stock using the Cat shield mounting holes. The sliders are 60" long and have two square 3/16" x 1.5" tube supports that are welded directly to the frame. I weight 230lbs and I can stand on them without them flexing at all.
