SERVICE SPECIFICATIONS, FLUIDS: Land Cruiser (FJ-, BJ-, HJ-, 40 & 55 series)
Website
www.linkedin.com
29Jun2005 (UTC +8)
Can this service specification info make it into the FAQ? I compiled this because I'm consolidating my LC maintenance info and it was easier to reference now. If there are any corrections, please feel free to tell me about it!
* I got this info from geniune Toyota publications & service manuals. Though I have the Haynes, Max Ellery, and other books, I didn't consult them for fear of getting erroneous info.
Vehicle: Toyota Land Cruiser (FJ-40, -43, -45, -55 series)
Engine model: F, 3.9L inline-6 cylinder gas-engine
Engine model: 2F, 4.2L inline-6 cylinder gas-engine
Fuel type, 2F: 91 RON, 85L
Engine oil, F: API SD, 7L
Engine oil, 2F: API SC, 7.8L (with oil filter change)
Coolant, F: drinkable water, 15.2L
Coolant, 2F: Ethylene-glycol based, 16.5L
Vehicle: Toyota Land Cruiser (BJ-40, -42, -43, -45, -46, series)
Engine model: B, 3.0L inline-4 cylinder diesel-engine
Engine model: 3B, 3.4L inline-4 cylinder diesel-engine
Fuel type: 40 cetane number, 85L
Engine oil: API CC, 6.7L (with oil filter change)
Coolant: Ethylene-glycol based, 13.3L
Vehicle: Toyota Land Cruiser (HJ-47)
Engine model: H, 4.0L inline-6 cylinder diesel-engine
Engine oil: API CC, 9.7L (with oil filter change)
Coolant: Ethylene-glycol based, 15.4L
Vehicle: Toyota Land Cruiser (FJ-40, -43, -44, -45, -55 series; BJ-40, -43 series; HJ-45, -47 series)
Transmission, J30: API GL-4, SAE 90, 1.7L
Transmission, H41: API GL-4, SAE 90, 3.1L
Transfer case, without PTO: API GL-4, SAE 90, 1.7L
Transfer case, with PTO: API GL-4, SAE 90, 2.1L
Differentials: API GL-5 hypoid gear oil, SAE 80w90, 2.5L (use LSD oil for LSDs)
Steering box: API GL-4, SAE 90, 600cc
Power steering: 0.8L (total, or 0.3L for pump only), ATF type Dexron
Front winch: API GL-4, SAE 90, 600cc
Chassis grease: Molybdenum-disulfide lithium-base, NLGI-2
Steering knuckle & front-axle shaft grease: Molybdenum-disulfide lithium-base, NLGI-2
Wheel bearing grease: Lithium-base multi-purpose, NLGI-2
Brake fluid: SAE J1703 or DOT-3
is this the same as the one n the 60 corner?
whichh one do you want to keep and which one to delete? posting in both FAQ's is great, no reason for two identical threads tho...
30Jun2005 (UTC +8)
Nope, this is different... this is for the 40 & 55 series, while the other is for the 60- & 70-series. Yet another one is for the 80-series, while the last is for the 105- & 105-series.
