40 and 62 parts for sale
Status
Not open for further replies.
NE GA
OK this is UPDATED with WHAT IS LEFT AND NEW PRICES
All are in Royston GA, 99% of stuff is used a few things are new and noted, shipping is not included on ANYTHING.
All 62 parts are off of an 89 Champagne and brown interior
Don’t be afraid to make an offer, most prices are off the cuff, and if they are WAY off either I don’t want to really sell it or I have no clue,,,,,,
40 parts
Disc brake knuckles 50 for the set
Early seat set 150$ little rough, but solid
Hard tops (fiberglass only) 75$
Hard top side panels, 20-40 each depending on rust
Multiple speedo cables 5 each and housings
40 speedo gear box??? 25
40 front center steering gear box 25$
E Brake parts OEM in plastic 5$
Bikini top rails, 20$
75 brake/clutch pedal cluster 15$
spare tire hooks for 75 and earlier 40 left and right 10$ each
75/40 visors 25/pr
75 gas filler neck 10$
door swing parts, stops door from opening too far off 75 30$
40 intake 150$
40 mated and planed intake exhaust manifold 225$
rear heater core 20$
Saginaw plate torch cut and cleaned up, no spacers welded or holes drilled 20$
75 emission s control box 10$
tow hooks 10$
Misc F parts, oil filler neck 10$
40 splash guards 10$
40 ubolt plates 5$
wiper motor either from 75/40 or fj62 $40
40 plastic fan with small crack that was repaired 5$
40 fan 30$
40 radiator screen 10$
75/40radiator bracket 30$
4 speed transfercase shifter 75$
4 speed transfercase 150$
4speed transmission 200$
hood hook, 5$
75/40gas filler neck cover 20$
75 cowl grill 10$
early 40 style air filter housing 20$
40 upper fender pieces 20$ each
40 alternators misc years 25$
horns 5$
Many many misc brackets for emissions, body, shackle mounts, shock mounts running board mounts just about anything
Steering boxes
Many emissions buzzers etc,, make offer
ubolt plates 5$
instrument cluster 2 different types gas gauge is in different place btwn the 2 one is 75 one is unknown 100
Front Bumper triangle flanges 10
76 chassis 1650
new diffs
new greasable shackles and pins
Toyota brakes front and rear
Toy brake lines new
Bushings new
Saginaw gear box installed
Oem style front bumper
Rear lights
Bumperettes
Partial Wiring harness
62 parts 90% of parts are from a tan/champagne
62 caliper rebuild kit 5$ each
62 gas filler door 5$
62 steering column parts, in pieces will not separate, tilt switch etc 30$
U-bolts plates 62 5$
Lap belts 5$
62 air filter housing 30$
knuckles 50 for set
wiper motor either from 75/40 or fj62 40$
62 instument cluster parts 25$ each
62 intake/manifold fan 50$
62 rear wiper arm 5$
62 rear spray bag with motor 20$
62 ac control cluster 35$
Used 62 oil pump 5$
62 ac vents/tubes 5$ each
shackles, plates, spring pins etc, make offer
brush guards to make homemade front bumper 25$
engine stand 50$ will not ship
gas separator not know if 40 or 62 5$
Acet/OXY torch set , medium victor 150$ one cutting tip one brazing
brake booster unknown possibly for 62…150$ or from a 75 40
Wiper motor not early style, you tell me,, 40$
tow hitch, bolts to frame, not sure what it is for 30$ looks like it is from a 60/62
I'm looking for the e-window control from the driver pannel. Need to have all the buttons.
Michael R_
'89 FJ62 DD - stock execpt for H42&tcase
I will take the tail gate carpet, rear wheel cyl (if available). Would you have the front calipers? Please email me at mpeagan at nc dot rr dot com. Thanks. Let me know how you want payment.
Mike Eagan
Raleigh, NC
sup...
i'll send you a PM, but mind if i swing by sometime this week and take a look at the stuff?
malphrus
pm'd every one, if I missed someone let me know, HUGE response, camera battery died so I will get pics ASAP to those that wanted,,
I am interested in parts for a 62
Battery tray $10
Rear grey carpet if in good shape?
Adjustable vents?
Do you have the hard lines that run back to the rear heater on a 62? They are diff than a 60, mine are rusted all to poo (I had to bypass my heater b/c of this) If so how much?
- Also the hard tranny and TC lines?
Thats all I can think of for now. thanks!
Status
