I just finished coating the inside of my tub with Herculiner.
Here are a few tips I've come up with from my experience.
One gallon is enough for one coat of the inside of the tub, with about a quart left for touch up and double coating areas with that will undergo more wear.
When applying the first coat, if you notice somewhere is a little thin, don't think you'll just get it with the second coat. It's nearly impossible to apply an entire even second coat. Because of the texture you can't see where you've applied a second coat. So you just basically look around for "holidays" and touch em up. But they're hard to find and I'm sure I missed a bunch. So make sure that first coat is thick and covers really well.
The directions read "mask off all areas that you wish not to be coated". My suggestion is to drape a peice of plastic over anything with in a quarter mile of your truck cause the s*** goes everywhere!!! I just masked off the lines where I wanted the paint to stop. But I didn't cover everything. So there's some splooge on the bell houseing, a little on a fender, here and there. So if you've got a really nice rig, cover everything.
Over all I'd have to say for $100, it's great. I hope it lasts, but i'll be getting a new tub in a couple years anyhow! It's easy to apply. Prep sucks, but that just comes with painting anything.
Oh yeah, I had the priveledge of a real paint shaker machine. The rubber particles seemed to be well mixed. But if you don't have one I'd spend some serious time stirring, otherwise the grit will be very uneven. I noticed when I got to the bottom of the can the paint got really really thick with the rubber. I probably could've mixed a little between coats.
Anyway as far as application it's cheap and easy. We'll have to see how it holds up.
Mike
Mike
