Background:
Have always had slight highway vibration, always assumed the culprit was either wheel balancing, slightly loose wheel bearings, or an out of balance d-shaft. Never bothered to check driveshaft phase. (Vibration was not nearly as bad as it has been in my experience when an out-of-phase d-shaft is the problem.)
Last week I installed Slee's Caster Plates, of course I was extremely pleased with the fit and finish, and more importantly the better caster. Took only about an hour and a half to install.
However, I immediatly noticed worsened vibration, even at lower speeds. As the rest of the week was very busy, I wrote it off as worse pinion angle and lived with it for 2 days.
Later that week, while tooling down the highway at 80-85 MPH the vibration was so unnerving I decided to call Slee and see if he had heard of any similar problems. (still assuming pinion angle). When the line was busy I pulled off, got under the truck, and found what the pictures show. A .2" deep groove worn/pounded into the the driveshaft slip yoke cover.... by the sway bar. And a driveshaft that was 90 degrees out of phase. Looked like the tech that last reinstalled it had an idea of what "in phase" should look like, but got careless and didn't quite get it.
Limped back down the road to a truck stop and bought a few wrenchs with the intention of pulling the driveshaft, instead yanked the sway-bar. (I don't keep tools other than the toyota kit in the truck around town).
SO- it looks like an out of phase driveshaft that was both moved closer to the sway bar and had a more *correct* pinion angle as a result of the caster plates was close enough to the sway bar to hit it- the unnerving vibration.
I got the shaft out as soon as I got home, it appears that only the "cover" of the slip yoke was damaged. However, it appears that compression travel is limited by maybe .5" or so. (Had a hard time getting it to compress enough to remove it from the truck).
Hopefully I'll be able to take it to the driveline shop on friday, however, I'm wondering if it would be ok to simply cut off that cover and install a shock-boot type rubber cover like many domestic trucks have. Also, does anyone have the fully compressed measurement, or could they take one? I want to see just how much travel is limited now...
Thanks and sorry for the worded post. I find it easier reading other people's posts when background information is included.
