The 40 interior is bare!
Now - which one do you prefer and why?
Duraback or Herculiner?
freightdog said:The 40 interior is bare!
fj40_rico said:I think that they are both about the same. I herculined the inside of the tub and durabak the whole cruiser (because durabak had more colors). But I think herculiner was a little thicker and holds to UV better.
- Rico.
Aalien said:I Herculined my K5 from the firewall back about three years ago. It applied well and looked good for a while. Now places are showing up where the paint underneath is showing through. These aren't rubbed through, more like faded out. I also don't think it is thick enough. I used a gallon on my interior, if I was to do it again I would definitly put a second gallon over it. The driver's floor board has held up better than I expected, and isn't worn. I have yet to decide what I am going to do to my FJ40, but I will look into other products first. If I use Herculiner again I will apply at least a second coat.
chuglife said:do you have any pictures of how that turned out? have been considering doing the same, a-là TJDIV
Paul_A said:Anyone applying this over interior rust spots? Not rot but where paint has worn off on floors and rear fender wells. Any concerns about blistering? How to prep the rust? Wire brush, sand, chemical treatment? Or not to apply over rust.
freightdog said:Thanks Ranger -
what color did you use?
I am just thinking flat black -
but it is good to know that one gallon = two coats -
fj40_rico said:I did on a couple of spots. I sanded it as much as I could with a wire brush but after a year the rust is coming through. The best thing would probably be do POR 15 first then the Herculiner.
- Rico.
