Safado said:and why do you lock the CDL?
2cruisers said:I take the top of a Windex or similar type spray bottle place it in the resorvoir and spray into another container. I can remove approx. 7 oz. Does'nt get it all but you can refill run your LC and do it again. Once it's clean you can replace the 7oz every other oil change and it always stays fresh. takes about 3 minutes.
got me one of my own after she saw me using the one from the kitchen on the ATF...
Kalawang said:Disconnect the return hose from the PS well and stick the end in a bottle. Run the engine and replace fluid in the PS well as it's level drops. When the fluid filling your bottle clears, you have flushed out the old fluid and it's time to turn off the engine, reconnect the return hose and top off the PS fluid level. After all is reconnected and topped off, run the engine with the cap of the PS well off. Look in the PS well for bubbles as a friend turns the steering lock to lock. When no more bubbles appear, you should be finished.
I did this PS flushing several times in an effort to get my PS more quiet because it was groaning. It didn't work for me and I finally had to remove the well and scrub out the parts manually. That worked. Flushing is only for mild problems,
RavenTai said:because of the action of the center differential if you do not lock the CDL and any one wheel is off the ground the parking "gear" will not stop the truck
if you do the other steps, set parking brake, block the rear wheels and lift on a flat surface you will still be OK, but it just takes a few seconds to lock the CDL having the redundancy of the parking pawl keep the 80 in place is a good thing,
had a good chance for a test of this tonight, last week end I removed the drivesahft to lube it and to diagnose a vibration (turned out to be tires out of ballance) I have not put the front shaft back in yet, been driving this week with the CDL locked.
the test: came into my driveway wicth has a slope in the middle, put in it in park, unlocked the CDL and let off the brake, the truck rolled down the hill in park,
interestingly enough got a chance to feel the Viscous coupler in action, on the steep part of the hill it kept the speed down, only letting it move at a set rate. when I got to the bottom and the driveway leveled off the speed went down the the drag of the VC tapered off still allowing the cruiser to creep along like the VC was not there. never experienced humping must take higher RPM.
so the VC steps up its force when the diffrence in RPM front to rear increases, and has almost no force at low RPM's.
cruiserman said:It's not very easy to see if there are bubbles in the PS reservoir. The fluid is very turbulent while the motor is running.
RavenTai said:https://forum.ih8mud.com/showthread.php?t=30395
post # 21 has directions, other posts in that thread have more info.
