This is from the Amsoil website, for 1999 UZJ100. Of course the part application numbers are for their products. The capacities appear accurate.
1999 TOYOTA LAND CRUISER 4.7L 8-cyl VIN Code 9 2UZ-FE
FILTERS
Oil Filter......SDF57
Oil Vapor Filter......N/R
Air Filter......TS162
Fuel Filter......GF325
Fuel Vapor Filter......N/R
Trans......TF171
BOSCH SPARK PLUGS
All submodels
Wire......NR
Plug......B4418
BOSCH WIPER BLADES
Driver side......B40920
Passenger side......B40920
Rear window......B40916
CHASSIS LUBRICATION
6-8 Fittings, 2 Plugs..........LB
Series 2000 Synthetic Racing Grease
Synthetic GHD Heavy-Duty EP Grease
Synthetic Multi-Purpose Grease NLGI #2
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......SL
Series 2000 Synthetic 0W-30 Motor Oil
SAE 5W-30 Synthetic Motor Oil
SAE 5W-30 XL-7500 Synthetic Motor Oil
Series 3000 Synthetic 5W-30 Heavy Duty Diesel Oil
Above 0°F......10W-30
All Temps......5W-30
Automatic Transmission.....AF3
Synthetic Automatic Transmission Fluid
Standard Differential, .....GL-5
Below -18°C......80W, 80W-90
SAE 80W-90 Synthetic Gear Lube
Series 2000 Synthetic Gear Lube
SAE 75W-90 Synthetic Gear Lube
Controlled Slip Differential, .....GL-5*
Slip-Lock Differential Additive
Transfer Case,.....GL-4
75W-90
Transfer Case,.....GL-5
75W-90
Fluids
Power Steering Fluid.....AF3
Brake Fluid.....HB
Hydraulic Brake Fluid, DOT-3 - Not Available Through Amsoil Click here for more information
Clutch Fluid.....HB
CAPACITIES
Engine, with filter..........7.2 quarts[1]
Cooling System, W/o rear heater Initial Fill..........15.0 quarts
Cooling System, W/ rear heater Initial Fill..........16.0 quarts
Automatic Transmission, Initial Fill..........3.7 quarts[2]
Automatic Transmission, Total Fill..........12.0 quarts
Differential, with Locking diff Rear..........6.8 pints
Differential, witho Locking diff Rear..........7.0 pints
Differential, Front..........3.6 pints
Transfer Case,..........2.7 pints
1. Capacity shown includes filter. after refill check oil level
2. With ENG automatic transmission operating temperature, shift through all
gears. Check fluid level in PARK and add fluid as needed.
TORQUES
Oil Drain Plug.....18 ft-lbs
Transfer case
Fill Plug.....27 ft-lbs
Drain Plug.....27 ft-lbs
FILTERS
Trans......TF171
BOSCH SPARK PLUGS
All submodels
Wire......NR
Plug......B4418
BOSCH WIPER BLADES
CHASSIS LUBRICATION
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......SL
75W-90
75W-90
Fluids
Brake Fluid.....HB
Clutch Fluid.....HB
CAPACITIES
TORQUES
Transfer case
