The steering wheel in my 94 has been making a weird noise, sounds like a metal to metal rubbing. I've ignored it for a few weeks but seems to be getting worse. Any ideas on what could cause a metal to metal rubbing.
landtank said:clock spring
Doc said:Check your PS fluid.
Mine was low.
I filled it up.
Wierd noise went away.
(it still groans occasionally, what's up with that?)
cruiserdan said:Almost.
That would be the case in a 95-up. In this case it is the horn contact pin rubbing on the contact ring on the back of the steering wheel. It needs to be greased.
Biff said:Dan,
How much of the steering wheel do I need to remove to greese it? Also what kind of greese do you recommend?
landtank said:Ya, but what size socket?
