Help! Florida is eating my tub.
Sunny Acres
A few pics of my tub before I start hacking it up. Everything's dropped and nothing lines up anymore. I'd really like to rebuild it instead of replacing it with a new one. No need to keep it stock.
it doesnt look too bad. Maybe get the CCOT extreme panels...the thicker stuff.........
The only way to tell the exact extent of damage is to remove the paint, perferably by sandblasting. One area of concern I see is the panel that runs behind the toolbox. Mine was the same way and I had to completely remove the body split it at the seam and replace the channel and sheetmetal in that area. Actually the visable rust on mine was alot less than yours, but once I started blasting was when I found major problems.
I can pretty much guarantee it'll be way worse once I get into it. How long did yours take?
I'm working on the same process, replacing the drivers side floor pan on a '78 FJ40, but I have the luxury of working on someone else's repair. The PO replaced most of the tub with sheet metal, so fixing it won't be as straight forward as working on an original tub.
Take pictures and let me know how it goes. Are you going to use CanadaCruiser panels or fab something yourself?
If you know what your doing with a welder and have mucho patience and fab skills then dive in......but if you only have avg welding/fab skills then find yourself anohter tub. My tub was like that and I was a novice to fabbing and welding. Took forever and a day without new panels. I will never do it again. Shoulda bought an alum tub from the get go. With all the time invested it cost about the same due to taking the paint off and finding patches of rot everywhere. Plus im in ohio and give it another 5 years before it starts rusting to hell again. :flipoff2: Good luck.
Redgreen - I PM'ed ya w/ my # gimme a holler.
Treeroot - That's what I'm talkin' about. Sweet work.
I'm getting some really good ideas together. Can't wait to finish up Al's rig and tear into mine!
Yeah my fab/welding skills are mediocre at best but it'll be a learning experience if nothing else.
Check out Iron Pig Offroad site. They used 1/8 step plate. If your not trying to restore to origional this IMO is the way to go. Way cheaper and easier (to weld) than origional panals. Also BudBuilt makes heavy steel quarter panals.
I'll try to take some pics of my '78 FJ40 tonight and post them. The PO replaced most of the tub with steel sheet. It must be 1/4" thick. The whole truck is bulletproof now. I just wish he had done a little better job of cutting out the old tub before welding over the top of it.
Hey Redgreen if ya want to swing by tomorrow or this weekend let me know...ill be out in the garage all weeking welding my truck back together...just drop me a line..Pmed ya!
hasta,
-Al
nice... thats what mine looked like about a month ago. Im up in Va so I had lots of rust too. One thing you might run into... After I hacked off the tub and built a new one I had problems with the rear fender and the rear portion of the door jam lining up. Turns out that after the tub came off and I replaced the driverside floorpan and mount, the floor droped about 1/2inch. Wasnt a big problem, just had to clamp the bottom end together with some vicegrips and tack weld.
BTW be carefull when your replacing the rear deck, I didnt and the floor is about 1/4 inch too tall. Causes problems with the ambi doors, I think ill just drop the rear lip to match :doh: .
sweet thanks for the info...but this 40 is turning into a 45...We got a fiberglass top that was chopped, so it ends right behind the seats and still has the rear hatch and wrap around windows...its looking so sweet..We will shoot some so that you can see the top then...
-Al
