Dual dampers
MA
Long story short, two Koni F150 rear dampers per wheel makes a nice handling/riding/offroading FZJ80. Single per wheel had roughly half the compression needed for my tastes, and were near perfect on rebound when set on #3, which increases the rebound dampening 100%. Two Konis set on #1 = #3. :)
Tilt head left... no more, just for Raven... :D
How in tarnation did you do that? Is that mount custom? How much lift?
:popcorn:
I'd really be interested in knowing the mods you did to make it accept dual struts. Who made your mounts? Is the rear bottom bolt just a really long bolt through both eyes? Are those regular Koni's? I didn't realize they were long enough to handle the lift.
I fabbed the mounts... some I like, some I don't. There is plenty of room up front, and just enough out back for dual 2" body dampers. The rear lower is a longer bolt used with a sleeve... works perfect. The Koni F150 units are almost 10", so they have a bit more travel... with lowered bumps and extended brackets, they work well. It would be better to take pictures of the mounts, rather than describe them. LMK if you want to see...
Of course I want to see- PICS!
If you don't mind....
Thanks.
Is there a viable option for this kind of thing "off the shelf", or is it all custom?
The next big mod on the 80 will be suspension, and I've always been partial to dual dampening set ups.
