- Joined
- May 31, 2007
- Threads
- 43
- Messages
- 187
My instructions say to connect one of the wires to the common wire on the headlight harness seems simple enough. However I have three questions:
-Can I just tie into a common wire right where it goes into on of the headlights or further up the harness before both lights branch off?
-Can anyone identify what wire is the common one? I guess it would be the one that is hot when both high and low beams are on?
-Finally there is a wire that is supposed to be wrapped around a spark plug wire or to a 12 volt source that is only how when the engine is running. Is there a good source for this under the hood? I'd rather not use the plug wire
