No More Smog, More Power!!!!
SOUTHERN NEVADA
Well, Its been a week sense we've pulled all the SMOG stuf off, Took off the Catalytic Convertor and instaled a Fake one, Took of the Exhaust Return Manifold Line. She's LOUD, But we've gotten a VERY NOTICABLE INCREASE OF POWER. Have'nt done a Gas Milage check yet. My Son will check that this weekend, Him and his friend's are doing a DUMOT Calif. trip this weekend to play in the sand. :D
My wife thinks that I've Lost My :censor: Mind, Our plan last month was to fix up the 92 and sell both Cruisers. But after putting the new Alterator and Heat Sheild in the 92, I'm just finding it very hard to let go of both of them :crybaby:
Don't drive by one of those "sniffers' that sniff your exhaust and take a pic of your plate as you drive by.
Saw them in Denver, I bet other big cities have them too.
you saw them in Denver? I didn't think Colorado was going to be doing the emissions on vehicles this year.I know that people have been talking about it for a couple years now. But I never would have guessed that they'd be putting sniffers out there if they were ever thinking about dropping the emissions.
I guess it's a good thing that I just moved here to West Texas this summer. :confused:
When I was 12, I took the baffle out of my 3 wheeler's muffler and I "thought" it had more power also. I believe the result of free flow exhaust and no add on's, (turbo, superchargers etc...) on a LC merely results in lower torque because of lack of back pressure. Any horsepower gains would be minimal at best if not "noticeable" at all. I would also bet that hearing the power would lessen your average gas mileage also.
Did you do a baseline performance test prior to the modification? it would be interesting to see how much the "power" is increased.
Myth? or Marketing?
http://www.flowmastermufflers.com/backpressure.html
http://en.wikipedia.org/wiki/Aftermarket_exhaust_parts
http://web.tampabay.rr.com/redroby/3liter/exhaust.html
http://www.proficientperformance.com/tech_back_pressure.php
http://nsxprime.com/FAQ/Miscellaneous/exhausttheory.htm
Excerpt from Flowmaster Site. One of the few Manufacturers who actually tell the truth.
Backpressure
This is a condition found in virtually any engine and is largely a function of exhaust system efficiency. In a racing engine, it is an issue of particular importance in as much as it relates to valve timing, exhaust port flow, contamination of fresh air/fuel charges, and other factors pertaining to efficient removal of exhaust residue from an engine's cylinders. Because of the effects of backpressure on an engine's ability to make power (torque), it is important to understand that as backpressure changes, other areas of an engine are affected.
For example, as backpressure increases (regardless of the cause), other engine components are typically optimized to compensate (or provide a partial solution) for this loss in exhaust system efficiency.
Perhaps one of the first areas an engine builder then addresses is the camshaft. By increasing the amount of effective valve overlap (and to some extent duration), some additional time is provided to evacuate the cylinder. However, this tends to reduce lower rpm torque, which then becomes compromised by higher operational rpm levels. But the trade-off here is that backpressure continues to increase with rpm and a point of diminishing returns is established. And typically, spark timing and fuel enrichment are adjusted to this less-than-ideal set of circumstances. Given these conditions, lets examine the changes we can expect to take place as backpressure is decreased.
By reducing the backpressure, some amounts of raw fuel (and fresh air) will be "scavenged" into the exhaust system. So by reducing the amount of air and fuel in the cylinder at the time of combustion.
A degree of cylinder pressure will be lost (a decrease in available torque)
Effective air/fuel mixtures will be leaner (possibly leading to parts damage).
Ignition spark requirements will change.
The exhaust system's temperature will rise (owing to the burning of air/fuel mixtures in the exhaust manifolding and pipes).
Exhaust gas temperatures will increase (particularly notable during engine dynamometer tests).
There will be a tendency of back-fire (or popping) during deceleration of the engine.
And while other conditions may arise (depending upon how a given engine is configured), the ones listed here are probably the most common.
In Flowmaster's experience, as an engine's backpressure is decreased, valve over-lap should be shortened. Again, for example, if an engine were running a camshaft of 106 degrees lobe separation before a backpressure reduction, selection of a cam of 112 degrees would tend to:
Retain more fresh air and fuel (thereby increasing cylinder pressure or torque)
Reduce or largely eliminate combustion in the exhaust system
Require less high rpm operation for optimum power
Require less ignition timing
Require a decrease in jet size
Decrease inlet charge contamination by a reduction of exhaust gas in the intake track
The purpose of all this information is not to focus on specific engine combinations. Rather, it is to address the issue of backpressure and how certain conditions will arise when it is reduced; in particular as with the use of Flowmaster's backpressure reducing components.
In fact, the use of Flowmaster systems (collectors, Y-pipes, etc.) can provide backpressure levels below that of open exhaust system. In that context, the selection of other engine components (in particular camshafts) should be viewed in this light. And while additional tuning is generally required, such steps can initially be approached as if the exhaust system was unrestricted.
For this reason, engine builders address increases in backpressure by longer overlap periods (sometimes more valve duration). This line of thinking can lead to the inefficient combustion conditions described elsewhere in this document; reduced power (torque), additional ignition spark timing and fuel delivery, and a general requirement for higher operating rpm.
NO SMOG CHECK HERE YET, But Washole (Reno) and Clark (Vegas) does.
Fake CATs and MUFFLERS and COMPUTER TWEEKERS are very common here. :cool:
Torque or not, She Starts faster and She's Peppier !!!!
Less backpressure, less torque.:confused:
Someone is clearly not comprehending.
An exhaust simplified to it's most basic form is a chimny.
Hot gas goes in one end, cooled down gas exits the other end.
When running at constant rpm the mass of gas going in is the same as the mass of the gas coming out.
Because there is a temperature drop between the gas fresh out of the engine and the gas out end of the chimny.
There is a pressure drop.
Gas automatically flows from high pressure areas to low pressure areas.
So a well proportioned exhaust system at operating temp actualy sucks the exhaust gas out of your engine.
This sucking effect increases cylinder filling capacity, thus increasing torque or horsepower.
Scavenging isn't a new mechanical engineering term with respect to piston pumps.
Please stop shooting from the hip.
In laymens terms, backpressure helps keep the raw fuel air mixture from being sucked through the combustion chamber into the exhaust before the exhaust valve(s) close.
I'm thinking about the seven spiritual works of mercy right now.
Most systems are designed with the manifold/header to be the restriction point int he exhaust. Simply put, the cylinders dont know the difference so long as the manifolds/downpipes aren't changed. This is an argument that could and does go on forever, or atleast until someone finds a way to check this on a LC.
Backpressure is required for proper torque, but whether it comes from the manifolds, the downpipes, or something further down is all speculation right now. Someone find me a 4wd dyno and pay for me to use it and I will gladly try a bunch of exhaust configurations to find out what does what.
WHAT A BI*CH !!!! The 92 is running better now than it has in years sense i pulled all that smog cr*p off. :bounce::bounce2::bounce::bounce2:
Now for the sucking part, I've had it up on "CRAIGS LIST" for the past month . I guy from Calif. wants to buy her. "" I told him that no way in hell will she pass CA Smog " , He's still flying out, :confused: Who knows. I'm not going to lie to the Guy.
:cheers:
MORE TO COME;p
Better for the environment and us all with catalytic converters in place.
It is a testing station but they are not there to penalize people. It can save you a trip to the emission station if you pass the roadside test ...they mail you based on your plates.
jeez I hate exhaust theory threads :rolleyes:
"backpressure increases torque"
crimp your tailpipe closed and see what happens :rolleyes:
good post on the backpressure. I was wondering about it. I had a few years ago an ATK 605 motorcycle that had the rotax 600 cc motor. It had a supertrap exhaust with a really restrictive and cap. The thing was a beast and was a true torque monster; but it would usually vibrate any bolts that weren't locktited out. THe exhaust bolts holding the cap on came out after a long ride and it blew the end cap out. I was about an hour from the truck so i kept riding.
The exhaust was really loud but the bike was a monster! it felt like it had been asleep with the exhaust cap on. It was SUPER FAST!
But i had heard it was bad on the motor. So i put a new one on when i got back home.
All i know is that she sounds LOUD, But when the Engine finaly heats up, She smooths out.
She has far more power :bounce::bounce2:, and gets better Gas milage :bounce::bounce2:. If i was going to keep her i would take off the Muffler too. :D
and the Doors and the Hood.
