Got the birfs done - a few observations
Olathe, KS
Well, it took about 16 hours total, but I got my birfields done and replaced my rotors at the same time. I followed Romer's write up in the FAQ, with a little help from Mariachi's DVD. Both EXCELLENT resources, I highly recommend them. I really didn't find the FSM that necessary, but some might.
The most comprehensive thing I've done to my rig up to this was replacing rotors and pads, with a few diff flush and refills thrown in. So this job is definitely something anyone can do. Just take your time, have everything ready to go, and do your research before hand.
I had a few observations that might help those of you who are considering tackling this job:
1. Tools. There are a few must haves that made a huge difference is doing this properly. Don't be a cheapskate, you're saving $1200 in labor:
0-100 lb torgue wrench
Brash Drifts - $8 from Harbor Freight
Snap Ring Pliers - $5 from HF
20 inch breaker bar
54mm socket - get this from Slee, it's only $25
Some 5 gallon buckets with either parts washer or diesel for soaking parts
2. If you're replacing your rotors at the same time, and do not have an impact gun, leave one tire on the ground and break these bolts loose before you remove the hub. Otherwise you'll have a hell of a time getting any leverage and you'll push your rotors around the driveway.
3. Allow yourself 2-3 days if you can. My knuckles, dust shield and other parts were covered in 10 years of grease and dirt. Soaking them overnight cleaned them up easily.
4. Have plently of Moly Grease on hand. I had 3 tubes of Valvoline Synthetic. I ended up needing about 6 total and had to run out in the middle of repacks.
5. Latex gloves - after having my hands soaked in fuel for several hours while cleaning parts, they started to tingle...not good. I just happened to have a box of gloves that came home with us from the hospital when my daughter was born :flipoff2:. Petrol products will eat the latex eventually, so have plenty on hand.
6. Go easy on the bolts that hold the rear seals on. Several of mine had pretty rusty threads and one head broke off. I was lucky - there was about 1/16 inch of threads sticking out and I was able to get channel locks on it. You might try soaking these with PB blaster before hand. These bolts can be found at the hardware store, I'd recommend replacing them all.
This is a very satisfying job to do yourself. If I can do, anyone can. Now, a pic of the results:
good job, bet it feels good driving around knowing your rig is well maintained.
did you replace any bearings?
Beno - do NOT say the H word around me please.
JM - Wheel bearings and races were still in great shape, so I didn't replace them. I did replace the trunion bearings in the knuckles, only because they came in C-Dan's Super Duper rebuild kit. They too were in good shape and probably didn't need to be replaced.
Before I do a dirty job like this I hit the coin-op car wash with some engine cleaner. Removing what you can before starting the job makes it much easier.
I think I'm going to start accumulating parts now. I'll probably hrow in some of the chromoly birfs at the same time, and keep the old ones as spares. Thoughts? Awesome job on those knuckles, by the way.:cheers:
I am planning to do my chromemolly bierfs soon, nice job and I am glad we have all this information!
It has been talked about in other posts that the chromoly birfs, though stronger, are not as wear resistant as the stock ones. For a trail rig they make sense. For a daily driver not so much. One way of using the chromoly birfs on a daily driver is to install locking front hubs.
David Sword
