refrigerator placement and wiring in 80 ?
miami, fl
where and how did you mount the refigerator? do you use a slide or slide lock?
pictures would be great. thanks
I have mine in the back like everyone else but check out Brian4x4's setup- simple and right at the rear passenger door. It makes a lot of sense for ease of access and weight distribution... has me reconsidering my design...
No current pics here at the office. I use Slee's metal slide for the fridge, mounted on a plywood platform bolted to the PS floor using the bolt holes from the 3rd row seats. For power, I routed a switched and unswitched wire to a dual West Marine 12v outlet mounted on the PS quarterpanel between the door and cubby hole.
where can i find brian4x4 setup?
Christo told me about this place:
http://macscustomtiedowns.com/Scripts/default.asp
Aluminum versa-track, working great in the back of my... Tacoma. :D Plus I can strap another cooler/toolbox/whatever on the other side.
And you thought you were rid of me....
TJK
