I finished installing the HFS 4" lift with shackles today. Most of everything was a breeze other than my diff angle in the back now. I did have to shave the front back bushings down where they squeeze in between the mount. No biggie with a bench grinder.
The lift rides and looks ten times better but I've got some major vib issues in the back. Yes I know, I should have measured the angles b/f I began but I'm too hard headed.
I installed a 4* shim up front and it seems to steer good and all but the back was giving me some vibrations so I took it appart and added a 4* to the rear with the flat side facing the rear bumper. Put it all back together and the vib is still there about the same.
Ok, I know you guys have told me but what is the correct way to fix this problem step by step??
Looks pretty good doesn't she!!
