Switching clutch fork sides...
Oceanside, CA (Fire Mountain)
Ok another issue popped up on my H55 to SBC conversion (73 FJ40)...
The original clutch fork was obviously on the drivers side w/ the 3 speed slave mounted on a Chevy bellhousing, but the Downey 4 speed adapter I'm using only has accomodations for bolting the slave on the passenger side. I've searched and read that it's an easy swap over but I have a few questions.
I'm using a 4 speed fork and TO bearing with Centerforce clutch assembly and I'm hoping to keep the 3 speed slave.
Do I just need a longer clutch hose to route over to the passenger side? I suppose I could have the adapter machined to keep the fork on the drivers side but that seems like a bit of extra work and I'm not sure if the Downey slave bracket is interchangeable.
Thanks
Dom, I had the same problem and just ran a hard line to the passenger side across the firewall and used the stock flex hose.
HTH
Ed
x2, I bent a new hard line as well and am still using the 3spd slave with the oem hose.
I cut the fittings off the old line and transfered them to the new line before I flared the new line.
X2:)
Ed
A decent double flare tool cost me $26 from OTC.....Owatonna Tool Corp.
Have yet to make one that did not work and not leak.
Easy bend stuff available at NAPA you can shape with your hand.
