Overdrive Light - Tranny Kaput?
Cave Creek AZ
So, having replaced the O2 sensors following the last EWL episode, it came back on around the same time that my overdrive stopped working. I have no 3rd gear I guess, and the rig is very slow to get up to speed from a stop. The OD light flashed intermittently, but does not engage. My question is whether this is likely to be simply electical, i.e., a loose OD switch, or a mechanical probelm, i.e., replacement tranny. Drives ok on the road, but definitely no OD. Thoughts?
Let me see if I can sort this out:
1) Your CEL is on again? Pull the codes!
2) Your OD light flashes. It's telling you you can pull tranny codes as well (using a different pair of check terminals).
3) OD is fourth, not third.
4) Slow to get up to speed is not an OD issue.
Summary: Pull the codes! :D
Curtis
Try disconnecting the battery, let it sit for a bit. Then reconnect. Beware of high idle after re-start. (basically reboot the computer)
Manual? Ahhmm....you wouldn't happen to have same? I think it's the solenoids myself, but seriously have no manual.
see the FSM thread just below this one and you can have the FSM downloaded shortly.
solenoids have been known to go out on the crude ( ;p ) "bus tranny" found in the 94.
Thanks!
Appreciate the elp - will let you know the results....
I mean "help"
The codes read (and I had my son the genius double check):
6:3 and 6:4
According to the FSM codes 62,63,64,65 indicate an electrical issue in the solenoid.
63 is "Severed No. 2 solenoid or short circuit - severed wire harness or short circuit"
64 is "Severed lock-up solenoid or short circuit - severed wire harness or short circuit"
With you getting both codes wouldn't it point to a common harness? Dunno.
As a side note - pulling the 10A DOME fuse will reset the tranny codes. Also, the OD button must be ON in order for the diagnostic indicator to work.
Ah!
Thanks MoJ,
I'll run the codes again with the OD swithch ON and let you know. Either way it's pointing to a solenoid problem. Not sure to your point what the makeup of the harness is, and whether both codes are simply pointing to the same thing.
