Oil Change - Filter removal
Ok, forgive me asking a really, really knucklehead question. How in the world do you guys remove the filter and install a new filter for an oil change? I've tried one of the "strap style" filter wrenches, but I can't seem to get the leverage to be able to get it. I can just barely get it started, but I'm afraid if I get it all the way off I won't be able to tigthen the new filter on after the change.
I'm looking at this dange thing, adding up my cost of a new filter and the oil, and I'm honestly thinking it would be better to have the stealership do it because it's the same cost (ok. $0.50) more at the dealer.
I've always changed my own oil, but this is by far the most difficult to get access to.
Why can't they all be like on my 84 Mercedes Diesel?!?!
Any suggestions?
You can take your new filter to autozone or the likes and buy a filter wrench. If you can squeeze into the area with your hands put your wifes Marigold gloves on and give it a good yank with your hands. Goodluck.:)
OH! you should not worry about putting the new one on as you will ONLY tighten the new filter with your hands NOT a wrench or strap. Goodluck. :)
I have this Vector Filter Wrench Part No. 17050
Get the 20004 too!
try removing it from underneath
The endcap wrench tool is key!
Or try wearing some clean latex or nitrile gloves for extra grip. I got my old filter off with the endcap wrench, but gloves would have probably worked too.
Thanks for the tips. Didn't realize it only went back on tightened without using the wrench. That was actually my big concern. I can get the thing off, but was worried I wouldn't get it back on properly and turn saving $1 on an oil change into a $5k rebuild.
Thanks for the heads up!
I ended up having to use a big ol set of channel locks (I had it changed at the dealer last time and they apparently put it on too tight). It was a pain in the A$% but it worked. I had to do it from the bottom. When I put the new one on I only put it on hand tight.
a small piece of sand paper in your hand with the grit side towarsd the filter will sometimes give you the extra grip that gets it done x10 on the no wrench to install bit...
K&N makes a high quality filter that has a 1 inch hex on the end so you can easily use a 1/2 drive ratchet and socket for removal. Hand tighten, remember! And drape a small piece of folded cardboard over the axle tube to reduce the mess from the draining oil.
John Davies
Spokane WA USA
The most convenient oil filter wrenches seem to be the "cap" type....unfortunately I never seem to have the right one that fits the filter...and have had them slip.
I finally bought a "three legged spider" wrench (I guess that's the right name) from NAPA - the legs have ridges cut into them to get a better grip on the filter. They are a little awkward and fiddly .. but once on and tight ... it works every time...on every size filter I use. It seems pretty solid as well.
I have tried most of them over the years ... straps,steel bands etc and this one seems to work the best..
Now that I only hand tighten mine, I can generally get them off with the "Kung Foo Grip" (TM IdahoDoug IIRC) from the top, usually with nitrile gloves. If I really need to, I use one of the large, two arm oil filter wrenches from the top to undo.
I usually make a little tin foil 'nest' under the filter to prevent too much spillage and as the filter starts to come off, put a bag over the filter.
Cheers, Hugh
I use cap wrenches. The only problem with them is that they tend to fall off the end of the ratchet and go swimming in the oil catch pan.
Kerplunk.
The wrench is mainly for removing them. For putting the new filter on I turn the new filter until it starts to snug, i.e. solid contact, then turn it somewhere around 1/4 or so turn more based on feel.
If you crank one of these down, you're just destroying the rubber ring at some point.
I removed mine from underneath. i used the "strap style" wrench, but could only move it 1/16 - 1/8th inch each time, so it took a little while. as soon as it was hand loose, i stuffed a big towl right up underneath it before pulling it the rest of the way off (and still got a face full, d'oh!). however, others on this thread are correct; just hand tighten the new filter up and you'll be ready to roll for the next time.
To clarify.... "hand tight" is rather subjective and I've seen gorillas that can really crank one down "hand tight." These will require a wrench to remove.
The instructions on the filter should be followed:
(Example...)
Lubricate the O-ring with a thin coat of fresh grease or oil. The vaunted '04 filters come pre-lubed.
Screw on the filter until the gasket (O-ring) makes contact. This is very subtle so pay attention to the "just makes contact" then, turn 1/2 turn. (might be 3/4 ... read the instructions with the filter.)
You also want to carefully inspect the sealing area on the block to be sure there is no trace of the old filter's O-ring or anything else. We have had a couple of reports of guys that used non-Toyota filters and found stuck O-rings (usually after some Exxon Valdez type of disaster in their garage.... or worse!)
-B-
When you hand tighten the filter, remember to smear some fresh oil around the rubber seal before installing the new filter.
To prevent spilling, I place a wide funnel under the filter. The hoses and such hold it up just fine. I point the skinny end directly in to the drain pan. No drips, no spills.
Now THAT I have to try. Thanks!
