Close to wrapping up my Hellroaring dual battery install in our 97. I'll be running a 2kw/4kw inverter in the rear cargo area to power a small microwave. I plan to run 1/0 welding lead, fused w/ a 250A ANL fuse block in the engine bay. With the HellRoaring isolator/combiner I chose, all loads should be run off the primary battery which is on the US driver side.
So, should I run the cable outside the truck along the frame rail, crossing to the passenger side in the engine bay? To do this I'll need to cut 1 ~2" hole or 2 ~ 1" holes in the floor near where I'll mount the inverter.
Another option would be to run the supply cable through the firewall and inside the cabin. Anyone done this? Any good "channels" to recess the cable in?
I also plan to ground the inverter to the frame. Since the main battery large ground runs to the block, is the frame sufficiently connected to the engine to conduct 250A? How, thru the tranny crossmember? Should I run another ground using 1/0 from the battery to the frame?
