The 7MGE Runs!!
I will shoot some pics
Switched the harness + vital electronic organs from the 87 and it runs sweet., smooth like butter.
Jim, you are probably correct with the problem with the late model harness, but now I can save that for a rainy day.
Took a water pump from a parts motor to fix that.
I have to take my electric fan controller back to JEGs because it does not work.
We are in "cleaning up" stage now.
Need to start fabricating exhaust.
:D
Looking good! What kind of power do you have it tuned for?
no tuning for me, I will just run junk yard parts and be happy with below stock hp. I am trying to keep this on the cheap.
I am just hoping I can get out of my own shadaw now. :D
Looks good karl I cant wait to see the difference it makes on the trail.
with the gearing we run I don't think the engine will make to much difference on the trail - could even be worse with the additional weight and torque causing breakage.
I was primarily looking for more power on the street. Looks like I might be able to wipe the cobwebs off of 5th gear now:D
What gears you running? My 7MGE is running 5.29, dual cases with stock gears, and 35s. I can idle down to 300RPM on the trail ! Your going to love it
And 5th is good too.
