Who sells a Spring over Axle kit that includes everything
Greetings All,
I am moving to AK in Jan time frame from texas and my suspension is worn out thats for sure. I want to do a Spring Over lift kit to fit 33-35 inch tires where can i get one that is easy to install and rides really great. I own a 72 FJ40 with all stock suspension and its hurting and moving to AK this spring. I appreciate any info you can give me.
Thanks Tom
Seems like I've seen this asked before in another tnhread... But, where are you gonna be stationed up here? ANC or FAI?
Mark...
I really can't see a "kit" providing much help with an SOA. There are enough differences in every rig that you are still gonna have to fabricate, tweak and adjust to the point that it would render any kit, IMHO pretty much... pointless.
Mark...
Moving to Fairbanks Area
Hello,
I am moving to the fairbanks area and got to get cruiser about how i need it so i dont have to do much work on it while I am there. Would you souggest just a 2.5 inch lift with SOA or what? I am open to any advice from you experienced cruiser guys and gals.
Thanks Thomas
Yogurt said:
Is SOA in front and coil over axel in back any good?
Send a pm to 76FJ40. He's got a 3-link in the rear with SOA up front, and I think it's safe to say he's pretty happy with it.
Here's his post in the articulation thread, but the shots are pre-soa in front. Take a close look at his avatar, too. https://forum.ih8mud.com/showpost.php?p=1316043&postcount=42
FjinIraq said:
Hello,
Thanks Thomas
It really depends on just what you are going to do with it. I generally reccomend an SOA and at least 35x12.5os for use on our trails. I urge larger and more aggressive tires if it will spend much time on the trails and less trime as a daily driver.
I don't reccomend any additional lift at all in conjunction with an SOA. A body lift if the SOA won't clear the size tires you want/need, but no lift spings with an SOA (except for 2.5 inch springs in the rear if you need some leveling to allow for loading up gear for the trail).
I also lean toward 4 wheel discs, power steering and steeper gears as tire size goes up.
I'd be careful jumping in to any big projects too close to your deadline for the PCS. The rig has to meet certain standards to be shipped. Including starting and running of course, functional Ebrake and a few other issues. A non-drivable project in the progress will be virtually im;possible to get shipped with a military move to Alaska. :(
Mark...
