Many have posted about wanting to put an fj-62 case behind there 80. Well durning my build up I am using a 62 series part time case and found out that it does not fit inside the frame rails of the 80 series. the 62 case bolts up to the same tranny as the 80series (91-92). Both 60series and 62series cases bolt up to the h55f...and with that logic. The 60 series case should bolt up and fit in between the frame rails.
I will be running an h55f/62 series part-time case with manual linkage...Because the vac shift on the 62 case is what causes it not to fit.
-Al
-Al
