LED tail light question
Maple Ridge, BC
I've decided to run LED tail lights in my cruiser, and can't figger out what to do about the empty holes left in the rear crossmember from the old lights. So I've got a couple ideas. Cut some steel and weld up the old holes and mount the lights on the tub, or make some brackets and mount the new lights in the stock holes on the crossmember. I'm at the point in my rebuild were I'm welding up the frame, and would like some input from people who have switched to LED lights.
Also check out this switch i got to run one of my future air lockers, its off a freightliner and is used to lock up the rear axles. It lites up when its on, and has a little tab you gotta push to move the switch, so you can't accdently lock up on the highway.
Cool switch, it is pneumatic? Neat!
"Cool switch, it is pneumatic? Neat!"
Yup air from the compressor gets hooked up to the red flange and the white flange goes to the locker. The two prongs are for the light, and it makes a cool swish sound when you turn it to the off positon.
heres how mine were when I got from the po. not the cleanest, but theres basically a bracket that was welded to the crossmember. the signals are also led but that bracket is bolted up from the bottom.
Cool, I think I'll put them in the stock light holes. I agree I really don't wanna chop up the body.
