How much would it cost to get the auto rebuilt if the shop has to pull, rebuild, and reinstall it?
Thank you,
Thank you,
tcb said:Mine cost $3200 including the t-case. If I had it to do all over again, I'd either go with a rebuilt A440f from Extreme in Austrailia or do an H55 Conversion.... as you can tell I'm not 100% satisfied with my rebuild.
they are different from what i understand its cost me 2 grand just to rebuild the transfer casejgordon said:Just out of curiosity, is the 62 tranny particularly difficult or do most people just not know how to rebuild trannies?
airlaird said:TCB, For $3200.00 couldn't you have bought a new Toyo tranny for that price?
cruiser88 said:they are different from what i understand its cost me 2 grand just to rebuild the transfer case
tcb said:Don't think so. I've heard that they are in the $6k range installed. I may be mistaken. Labor is a mamma jamma on this tranny, it's enormous..... That price also included $500 for the transfer case and taxes.... So it was around $2400 or so for the transmission.
Plus I was 3 1/2 hours away from home, so I didn't exactly have a whole lot of options. It was a shop that a couple of cruiser heads recommended, so its what I went with. FWIW, the shop that did mine immediately raised the price on the A440F rebuild after doing mine. Ask Euclid what the same shop quoted him.
euclid said:Price went up to $5K. They are the best shop around, and I trust they did their best on tcb's but they still screwed it up. When I showed them the website and info on the exteme transmissions the same shop said it was a better option.
No vodoo involved in the a440, but it aint no simple deal either. Find someone who knows the transmission then cross your fingers.
Again, I'm very pleased with my extreme, but it aint cheap or easy to get.
euclid said:Some of what you describe would be solved by adding the custom valve body from extreme. Risk in adding that is that it would increase fluid pressures in the tranny and it's hard to say if the rebuild would hold up to it. Most of what bugs you is controled by the valve body.
