Bomar
I am starting this thread to show a super easy way to remove the LSPV system from your 62...
Items needed:
- 10 MM flare nut wrench
- elbow brake line union (got mine from the front of a FJ60 parts truck) (1st picture)
- 1 brake bleeder (got it from a 2nd 4Runner in junk yard) (1st pic)
NOTE: Alot of people add a brake prop valve but I have done a few and not used one yet so if you want one use it....if not then you will be good also.
On the lspv there are 3 brake lines. You will join the rear line (goes to rear brakes) As the line come off the frame rail the middle line is the return line that you will disconnect and leave. (2nd photo) The other 2 lines will be joined with a union. (3rd photo)
In the front passenger wheelwell you will find the brake unions for the truck. The one closest to the front of the truck will have 3 lines coming out of it. Disconnect the rear line that points towards the motor that is where you place the brake bleeder. (4th photo)
Bleed brakes and clean up mess and you will have a lot firmer brakes.
Items needed:
